If a paper jam occurs in a paper drawer, a screen prompting you to remove the jammed paper appears on the touch panel display. Check the location of the paper jam, and follow the procedure described below, while referring to the directions that appear on the touch panel display, to remove the jammed paper.
The Cassette Module-AA1 is an optional product.
If paper is loaded in the multi-purpose tray, remove the loaded paper.
