e-Manual
Top
Site map
Help
Glossary
Contents
Search
Previous
Next
Print this topic
Category:
Before You Start Using This Machine
Flow of Settings
Basic Operations
Optional Products/Software
Settings/Registration
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Web Access
Scanner
Quick Menu
Status Monitor/Cancel
Print
Network
Remote UI
MEAP
Security
Practical Workflows
How to Use This Manual
Expand all
Collapse all
Category Top
Overview of This Function
Overview of Login Services
Login Screens
SSO-H (Single Sign-On H)
Login Screens
System Requirements
Before Logging In to SSO-H
Logging In to SMS
Logging Out from SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Logging In to SSO-H
Menu for Administrators
Registering/Editing User Data for LDAP Server Authentication
Setting the SSO-H
Setting Password Restrictions
Setting the Lockout Function
Menu for General Users
SDL Format
NetSpot Accountant 3.x Format
NetSpot Accountant 4.x Format
Troubleshooting
Other Trouble
Print all
Keyword:
Search options
Search all categories
Search from below categories
Flow of Settings
Basic Operations
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Web Access
Scanner
Quick Menu
Print
Network
Remote UI
MEAP
Security
Practical Workflows
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Specify search conditions
Search Method
Top
MEAP
Logging In to SMS
0C1Y-1J8
Click [Log Out from SMS].
When you finish using SMS, make sure you log out. If you close the Web browser without logging out, SMS becomes temporarily inaccessible.
Back to Top
