Registering Multi-Purpose Tray Default Settings
This setting is useful if you always load the same paper size and type into the multi-purpose tray by registering the default paper size and type for the tray in advance.
If the multi-purpose tray is registered as a paper source for receiving faxes, the paper loaded in the multi-purpose tray is always used for printing received faxes.
Be sure to correctly set the paper type. If the type of paper is not set correctly, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty and require a service repair, or the paper could jam.
Press [Preferences] → [Paper Settings] → [Register Multi-Purpose Tray Defaults].
Press [On] → [Register].
If you do not want to register the setting, press [Off] → proceed to step 6.
4.
Select the desired paper size.
If you want to select a standard paper size:
If you want to select a custom paper size:
If you want to select an envelope type:
Select the desired paper size → press [Next].
To select an A or B series paper size, press [A/B Size].
Press [Custom Size].
Press [X] and [Y] → enter each value → press [OK].
You can also select a size key ([S1] to [S4]) containing a stored paper size setting, instead of entering values.
Press [Next].
Press [Envelope].
Select the type of envelope → press [OK].
Press [Next] → [OK] → proceed to step 6.
Select the correct type for the envelopes. Failing to do so may cause a paper jam.
Press [Next].
5.
Select the desired paper type → press [OK].
If you select [Plain], select the paper weight from [Plain Paper Weight Set.].
[Transparency] can be selected only if you select [LTR] as the paper size.
For more information on paper types, see "Available Paper Stock."
You can register paper types that are not displayed on the detailed settings list in <Paper Settings: Paper Type>. For instructions on registering paper types, see "Registering/Editing Custom Paper Types."
6.
Press [OK].
To use the multi-purpose tray as a paper source for [Copy], [Access Stored Files], [Receive/Fax], or [Other], you must set so that the multi-purpose tray is eligible for Paper Drawer Auto Selection. (See "Enabling Paper Drawer Auto Selection.")
» Settings/Registration » Preferences » Paper Settings » Registering Multi-Purpose Tray Default Settings
0C1Y-056
