[Consider Paper Type]
If the selected paper source runs out of paper during a copy job, another paper source with the same paper type is selected as the result of Auto Drawer Switching. If you set to 'On', paper sources with different paper types are not selected even when the paper source are loaded with the same paper size.
Automatic Paper Selection*1
If [Consider Paper Type] is set to 'On'
Plain 1, Plain 2, Recycled, Custom*2
If there is a paper source with the same paper size, type, and color, the machine automatically feeds from that paper source and continues printing.
If [Consider Paper Type] is set to 'Off'
Plain 1, Plain 2, Recycled, Color, Heavy 1, Custom*3
If there is a paper source with the same paper size but a different paper type*3, the machine automatically feeds from that paper source and continues printing.
Auto Drawer Switching*5
If the paper type is specified*4
All paper types available on the machine are eligible for use with Automatic Paper Selection if they match the paper types specified on the printer driver.
If the paper type is not specified
If there is a paper source with the same paper size and the paper type can be used with Automatic Paper Selection, the machine automatically feeds from that paper source and continues printing.
Auto Drawer Switching*6
Auto Drawer Switching*8
Plain 1, Plain 2, Recycled, Color, Custom*7
If there is a paper source with the same paper type and color, the machine automatically feeds from that paper source and continues printing.
(Settings/Registration).
At least one of the paper sources besides the multi-purpose tray must be set to 'On'.
If you select [Copy], you can set whether to consider the paper type.
If you set [Consider Paper Type] to 'On', paper is not fed from another paper source when the original paper source runs out of paper, unless another paper source is loaded with paper of the same size and type. For more information on stored paper types, see "Checking the Status of Consumables and Other Information."
If you set [Consider Paper Type] to 'Off', paper is fed from another paper source when paper in the current paper source runs out, as long as the same paper size is loaded in that paper source.
