Changing/Initializing the Default Settings for the Copy Function
You can change/initialize the default settings for [Copy].
This mode can be set when the Copy function is available for use. For information on the optional products required to use the Copy function, see
"Optional Products Required for Each Function."
Even if a cascade copy printer is stored in Default Settings, if the main power of this machine or the cascade copy printer is turned OFF and ON again, the stored settings change to Local Printer. To use the stored cascade copy printer as the Default Setting, it is necessary to register the Default Settings again.
Changing the Default Settings for the Copy Function
Press
![](./images/book_images/b_in_Add.jpg)
(Settings/Registration).
Press [Function Settings] → [Copy] → [Change Default Settings].
Press [Register].
The current copy settings are set as the default settings.
4.
Press [Yes].
Press
Press [Initialize].
4.
Press [Yes].
