The following settings are necessary for SSO-H authentication to be performed when sending device information.
Register the user name, password, and domain name that will use SSO-H authentication on the host machine.
On the client machine, set whether SSO-H authentication is required on the host machine when delivering device information.
For more information, see "Setting SSO-H Authentication for Device Information Delivery Settings."
Delivered Information
Contents
Notes
Address Book
Address List information stored in [Register Destinations] in [Set Destination].
[Function Settings] - [Receive/Forward] - [Common Settings] - [Forwarding Settings]
[Function Settings] - [Send] - [Common Settings] - [Register Favorite Settings]
[Function Settings] - [Send] - [Common Settings] - [Edit Favorite Settings]
All of the currently stored destinations are deleted, and then the destinations that are delivered are registered.
Department ID
[Management Settings] - [User Management] - [System Manager Information Settings]
[Management Settings] - [User Management] -[Department ID Management]
Only Department IDs existing in the client machines are deleted.
If an identical Department ID exists in the client machine, its password and set counter limits are overwritten. Counter values, however, are not overwritten.
If a Department ID exists in the host machine, but not in the client machine, the Department ID, password, and set counter limits from the host machine are added to the client machine. Counter values are also added and reset.
If the Copy Card Reader-F1 is attached to the host machine and is not attached to the client machine, or vice versa, only System Manager Settings are delivered.
Printer Settings
[Function Settings] - [Printer] -[Printer Settings]
Some Settings/Registration settings are not delivered. For more information, see "Function Settings: Printer."
Paper Information
[Preferences] - [Paper Settings] - [Paper Type Management Settings]
The user-defined paper types that are already stored are delivered. Upon exporting, the user-defined paper information is duplicated and delivered. Upon importing, the user-defined paper types that are already stored are overwritten by the paper information.
Settings/Registration Value
Settings made from the Settings/Registration screen (excluding the above settings)
Some Settings/Registration settings are not delivered. For more information, see "Settings/Registration Table."
Information for mail boxes set with a password is not delivered. Information for mail boxes set with a password in the client machine is not overwritten.
If you do not deliver [Settings/Registration Value] and [Address Book] at the same time, the settings in [URL Send Settings] for [Set Fax/I-Fax Inbox] and [Mail Box Settings] may be erased.
Web Access Favorites
[Web Access Favorites]
Can only be delivered if the Web Access function is activated on both the client and host machine.
Workflow Composer
Flows
All of the flows currently registered in the client machine are deleted, and then the flows that are delivered are registered.
Delivery and reception is only performed if Workflow Composer is started on both the client and host machines.
For information on Workflow Composer, see the instruction manual that comes with it. |
Preparing for delivery and updating the information after it is received may take several minutes. Do not turn the machine's main power OFF until these operations are complete. Otherwise, the machine may malfunction.
Device information can be shared between machines of the same model (imageRUNNER ADVANCE 6275/6265/6255). However, some information may not be delivered correctly depending on the optional products that are available for use on the machine.
If [Restrict Receiving Device Information] for <Receiving Settings> is set to 'Off', the machine can receive device information delivered from different machine models. (See "Setting the Receiving Machine.") However, some information may not be delivered correctly.
Device information cannot be delivered if the System Manager ID and System PIN registered in the client machine differ from the System Manager ID and System PIN registered in the host machine.
Unique machine information, such as the IP address, is not delivered.
The machine can deliver device information to devices using IPv4 or devices using IPv6.
