[Portrait]:
Portrait refers to an original in vertical orientation:
the shorter edges are at the top and bottom of the original.
[Landscape]:
Landscape refers to an original in horizontal orientation:
the shorter edges are at the left and right of the original.
If you set any two of [Page Numbering], [Copy Set Numbering], [Watermark], or [Print Date] to print in the same position, a confirmation message appears when you press
You can specify a number of digits between '2' and '5'.
Example:
If the page number is 10, and the number of digits is 2:10 → 10
If the page number is 10, and the number of digits is 5:10 → 00010
If the specified number of digits is fewer than the number of digits of the actual page number, the setting is invalid.
Printing performance may not be optimal, depending on the original content and combination of settings.
