If you are copying on the back side of a previously printed sheet, load the paper as indicated below.
Paper drawer: Load the side to copy on face up.
Multi-purpose tray: Load the side to copy on face down.
When setting the stapling location to one of the following, stapling is applied from the back sides of the printouts, and the claws of the staple appear on the front side (first page) of the printouts.
In horizontal (landscape) orientation, staple in the upper left
In horizontal (landscape) orientation, staple in the lower right
In vertical (portrait) orientation, staple in the lower left
In vertical (portrait) orientation, staple in the upper right
Other Settings
Example of Stapling Position
Top Right
![]() LGL, LTR, EXEC
Top Right
Bottom Right
Bottom Right
Preprinted paper
Loading location: Paper drawer
Preprinted paper: Face up |
Loading location: Multi-purpose tray
Preprinted paper: Face down |
Original
Loading location: Platen glass
Original: Face down |
Stapling setting
Top Right
Top Right
Bottom Right
Bottom Right
Loading location: Feeder
Original: Face up |
Other Settings
Top Left
Top Left
Bottom Left
Bottom Left
Preprinted paper
Original
Stapling setting
Top Left
Top Left
Bottom Left
Bottom Left
Original: Face up |
Other Settings
Example Output
![]() LGL, LTR, STMT, EXEC
Preprinted paper
Original
Original: Face down
Original: Face up
Function
Functions that Cannot Be Used in Combination
Preset Zoom
Zoom by Percentage*1, XY Ratio*1, Auto Zoom*1, Copy ID Card
Zoom by Percentage
Preset Zoom*1, XY Ratio*1, Auto Zoom*1, Copy ID Card
XY Ratio
Preset Zoom*1, Zoom by Percentage*1, Auto Zoom*1, Copy ID Card
Auto Zoom
Preset Zoom*1, Zoom by Percentage*1, XY Ratio*1, Copy ID Card
Fit to Page
N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Page Numbering, Copy Set Numbering, Watermark, Print Date, Copy ID Card
Function
Manual Paper Selection
Custom Size*1
Automatic Paper Selection(LTR/LGL)
Custom Size*1, N on 1*1, Erase Original Frame*1, Erase Book Frame*1, Erase Binding*1, Shift (By Position)*1, Shift (By Numeric Keys)*1, Copy ID Card*1
Custom Size
Manual Paper Selection, Automatic Paper Selection(LTR/LGL)*1, 1-Sided
Scanning Originals Loaded in the Feeder
Copy ID Card
Function
Collate
Group*1, Offset Collate*1, Offset Group*1, Staple*1, Copy ID Card
Group
Collate*1, Offset Collate*1, Offset Group*1, Staple*1, Copy Set Numbering, Secure Watermark*2, Copy ID Card
Offset Collate
Collate*1, Group*1, Offset Group*1, Staple*1, Copy ID Card
Offset Group
Collate*1, Group*1, Offset Collate*1, Copy Set Numbering, Secure Watermark*2, Copy ID Card
Staple
Collate*1, Group*1, Offset Collate, Copy ID Card
Function
1-Sided
Custom Size, 2-Sided
2-Sided
Custom Size, 1-Sided
2-Sided
1-Sided
N on 1
Automatic Paper Selection(LTR/LGL), Fit to Page, Custom Size, Erase Original Frame, Erase Book Frame, Shift (By Numeric Keys), Copy ID Card
Automatic Paper Selection(LTR/LGL), Fit to Page, N on 1, Erase Book Frame*1, Erase Binding*1, Page Numbering, Copy Set Numbering, Watermark, Print Date, Copy ID Card
Erase Book Frame
Automatic Paper Selection(LTR/LGL), Fit to Page, N on 1, Erase Original Frame*1, Erase Binding*1, Page Numbering, Copy Set Numbering, Watermark, Print Date, Copy ID Card
Erase Binding
Automatic Paper Selection(LTR/LGL), Fit to Page, Erase Original Frame*1, Erase Book Frame*1, Page Numbering, Copy Set Numbering, Watermark, Print Date, Copy ID Card
Interrupt
Copy ID Card
Function
Shift (By Position)
Automatic Paper Selection(LTR/LGL), Copy ID Card, Shift (By Numeric Keys)*1
Automatic Paper Selection(LTR/LGL), N on 1, Shift (By Position)*1, Page Numbering, Copy Set Numbering, Watermark, Print Date, Copy ID Card
Sharpness
Secure Watermark, Scan Lock Information (TL Code), Tracking Information
Function
Page Numbering
Fit to Page, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Between Batches, Copy Set Numbering*3, Watermark*3, Print Date*3 Secure Watermark, Copy ID Card, Scan Lock Information (TL Code), Tracking Information
Copy Set Numbering
Fit to Page, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Between Batches, Group, Offset Group, Page Numbering*3, Watermark*3, Print Date*3, Secure Watermark, Copy ID Card, Scan Lock Information (TL Code), Tracking Information
Watermark
Fit to Page, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Page Numbering*3, Copy Set Numbering*3, Print Date*3, Secure Watermark, Copy ID Card
Print Date
Fit to Page, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Between Batches, Page Numbering*3, Copy Set Numbering*3, Watermark*3, Secure Watermark, Copy ID Card, Scan Lock Information (TL Code), Tracking Information
Copy ID Card
Preset Zoom, Zoom by Percentage, XY Independent, Auto Zoom, Fit to Page, Automatic Paper Selection(LTR/LGL), Custom Size, Between Batches, Collate, Group, Offset Collate, Offset Group, Staple, Interrupt, 1sided
Sharpness, Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction), Adjust One-Touch Color (Sepia Tone), Color Balance, Color Balance (Fine Adjust Density), Single Color, Between Batches, Copy Set Numbering, Print Date, Watermark, Two Colors, Secure Watermark
Secure Watermark
Sharpness, Adjust One-Touch Color (Vivid Colors/Tranquil Colors), Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction), Adjust One-Touch Color (Sepia Tone), Color Balance, Color Balance (Fine Adjust Density), Single Color, Between Batches, Copy Set Numbering, Print Date, Watermark, Two Colors, Scan Lock Information (TL Code), Tracking Information
Function
Auto (Color/Black)
Full Color*1, Black*1, Adjust One-Touch Color (Sepia Tone)*1, Single Color*1, Two Colors*1
Full Color
Auto (Color/Black)*1, Black*1, Adjust One-Touch Color (Sepia Tone)*1, Single Color*1, Two Colors*1
Black
Auto (Color/Black)*1, Full Color*1, Adjust One-Touch Color (Sepia Tone)*1, Single Color*1, Two Colors*1
Background Density (Auto)
Background Density (Adjust Each Color)*1, Background Density (Adjust All Colors)*1
Background Density (Auto), Background Density (Adjust All Colors)
Background Density (Auto), Background Density (Adjust Each Color)
Between Batches, Secure Watermark, Scan Lock Information (TL Code), Tracking Information
Color Balance*1, Color Balance (Fine Adjust Density)*1, Between Batches, Secure Watermark, Scan Lock Information (TL Code), Tracking Information
Auto (Color/Black)*1, Full Color*1, Black*1, Single Color, Between Batches, Page Numbering, Copy Set Numbering, Watermark, Print Date, Two Colors, Secure Watermark, Scan Lock Information (TL Code), Tracking Information
Color Balance
Adjust One-Touch Color (Lighten Image/Darken Image/Highlight Reproduction)*1, Between Batches, Secure Watermark, Scan Lock Information (TL Code), Tracking Information
Single Color
Auto (Color/Black)*1, Full Color*1, Black*1, Adjust One-Touch Color (Sepia Tone), Two Colors*1, Secure Watermark, Scan Lock Information (TL Code), Tracking Information
Two Colors
Auto (Color/Black)*1, Full Color*1, Black*1, Adjust One-Touch Color (Sepia Tone), Single Color*1, Page Numbering, Copy Set Numbering, Watermark, Print Date, Secure Watermark, Scan Lock Information (TL Code), Tracking Information
