      0SU0-05Y
      Department ID Management Report
      When Department ID Management is enabled, you can print a report to check the total number of pages that were printed for each Department ID. The report enables you to monitor usage and improve management.
      Example:
      1
      Press .
      2
      Use / to select <Output Reports>, and press .
      3
      Select <Print List>  <Department ID Management Report>.
      If the logon screen appears, enter the correct ID and PIN using the numeric keys, and then press . Logging on to the Machine
      4
      Check that the size and type of paper displayed on the screen is loaded in the machine, and press .
      5
      Select <Yes>, and press .
