Faxing with AirPrint (imageRUNNER 1435iF Only)
AirPrint enables you to send faxes from a Mac in almost the same way as when you print from a Mac.
System Requirements
To send faxes with AirPrint, you need a Mac with Mac OS X 10.9 or later installed.
Network Environment
You need one of the following environments.
The Mac and the machine are connected to the same LAN.
The Mac and the machine are connected via USB.
NOTE:
When using USB connection
Set <Select OS for USB Connected PC> to <Mac OS>.
Faxing from Mac
1
Make sure that the machine is turned ON and that it is connected to the Mac.
For more information about settings and operation procedures of the wireless LAN router or mobile devices, see the instruction manuals for the devices or contact the manufacturer.
2
Add the machine to your Mac from [System Preferences]
![](./images/book_images/b_key_arrow_right.gif)
[Printers & Scanners].
This operation is not necessary if the registration has already been performed for printing or scanning.
3
Open a document in an application and display the print dialog box.
How to display the print dialog box differs for each application. For more information, see the instruction manual for the application you are using.
4
Select this machine in the print dialog box.
The printers connected to the Mac are displayed. Select the fax driver of this machine in this step.
5
Specify the destination.
6
Click [Fax].
Fax sending starts.
