Utilizing the Machine through Applications
You can print and scan by using applications from a mobile device connected to the machine. Various applications including those exclusive to Canon are supported. Select the application that best suits your device, intended purpose, and situation.
Printing/Scanning via Canon PRINT Business
You can print from mobile devices that support iOS/Android, or place and scan documents on the machine, then send them to a mobile device. When printing, it is not necessary to perform operations on the machine. To perform scanning, start Canon PRINT Business on the mobile device after selecting <On> for <Enable Canon Mobile Scanning> in <System Management Settings> on the machine. For more information on supported operating systems, detailed setting methods, and operations, see the Canon website (
http://www.canon.com/).
Printing with Canon Print Service
You can easily print from the menu of applications that support the Android print subsystem. For more information on supported operating systems and detailed settings and procedures, see the Canon website (
Using AirPrint
You can print, scan, or fax without using drivers by sending print data from Apple devices.
Using AirPrint
Using Google Cloud Print
You can print from an application or service that supports Google Cloud Print. You can print by remotely operating the machine at any time and from anywhere, for example even while you are on the go.
Printing with Mopria™
This machine also supports Mopria™. Using Mopria™ allows you to print with printers of different models from different manufacturers by using common operations and common settings. For example, assume that Mopria™ compatible printers of different models from different manufacturers are installed in your office, at your place, or at places you are visiting. You can then print with any of those printers by using Mopria™ without the need to install the respective dedicated applications on them. For details about the models supporting Mopria™ and the system requirements, see
http://www.mopria.org.
Viewing Mopria™ Settings
Log on to the Remote UI in System Manager Mode (
Starting the Remote UI)
[Settings/Registration]
[Network Settings]
[Mopria Settings]
[Edit...]
Check that the [Use Mopria] check box is selected
[OK]
Printing from Windows Phone (Windows 10 Mobile and Later)
You can perform printing from a Windows Phone without downloading a dedicated application or installing a driver. Make sure that the <Use WSD Print>, <Use WSD Browsing>, and <Use Multicast Discovery> settings in <WSD Settings> are enabled.
WSD Settings
