Paper Creases
Is paper loaded correctly?
If paper is not loaded below the load limit line or is loaded obliquely, it may crease.
Are you using paper that has absorbed moisture?
Replace with appropriate paper.
Are you using appropriate paper?
Check usable paper, and replace with appropriate paper.
Paper Curls
Check usable paper, and replace with appropriate paper. Also, specify the paper size and type settings properly.
If the use of appropriate paper does not solve the problem, change the <Special Mode P> setting or <Special Mode N> setting.
