All the settings about the timer are listed with short descriptions. Default settings are marked with a dagger (
Asterisks (*)
Settings marked with "*1" have different defaults depending on the country or region of purchase.
Settings marked with "*2" cannot be exported or imported.
YYYY MM/DD
MM/DD/YYYY
![]() DD/MM YYYY
<Timer Settings>
<Date/Time Settings>
<Date Format>
Select the date format
12 Hour (AM/PM)
![]() 24 Hour
<Timer Settings>
<Time Format>
Select the time format
to move the cursor, and use the numeric keys or
to specify the date and time or switch between <AM>/<PM>.|
Set <Time Zone> before setting the current date and time. If the <Time Zone> setting is changed, the current date and time are also changed accordingly.
The current date and time cannot be changed for 1 hour after daylight saving time is in effect.
<Timer Settings>
<Current Date/Time Settings>
Set the date and time
UTC-12:00 to UTC-5:00
to UTC+12:00 |
UTC
Coordinated Universal Time (UTC) is the primary time standard by which the world regulates clocks and time. The correct UTC time zone setting is required for Internet communications.
<Timer Settings>
<Time Zone>
Select a time zone
Off
![]() On
Start: Month, Week, Day
End: Month, Week, Day |
<Timer Settings>
<Daylight Saving Time Settings>
<On>
Specify the start month, week, and day
<Apply>
Specify the end month, week, and day
<Apply>
0 (Auto Reset is disabled.)
1 to 2
to 9 (min.) |
<Timer Settings>
<Auto Reset Time>
Set the Auto Reset time
The screen displayed after the Auto Reset is performed can be selected in <Function After Auto Reset>.
Default Function
![]() Selected Function
<Timer Settings>
Select <Default Function> or <Selected Function>
3 to 5
to 240 (min.) |
0 (The machine remains online.)
1 to 5
to 60 (min.) |
<Timer Settings>
<Auto Offline Time>
Set the time period
