Receiving Fax Information Services
Through fax information services, you can easily get a variety of helpful lifestyle and work information from companies and organizations. This section describes a typical procedure for receiving these services.
Depending on the service, actual procedures may differ from the ones described below. Follow the procedures for the service you are using.
1
Press
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_fax18.gif)
2
Press
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_hook.gif)
(Hook).
If an external telephone is connected to the machine, you can pick up the handset instead of pressing
(Hook).
3
When you hear a dial tone, dial the information service.
4
When the recorded message of the information service answers, press
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_tone18.gif)
This step is unnecessary if the machine is using a tone-dialing line.
5
Use the numeric keys to enter the service number assigned for the information you want to receive.
You can also use the keypad on the telephone to enter the information service number.
6
Use
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_up18.gif)
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_down18.gif)
to select <Start Receiving>, and press
![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_ok18.gif)
to start receiving faxes.
If you have picked up the handset, hang it up.
LINKS
