You can select a destination from the three most previously used destinations. When you specify a previously used destination, the machine also sets the same fax settings such as density you used the last time you sent documents to that destination.
When <Restrict Resending from Log> is set to <On>, you cannot use this function. Disabling Use of Previously Used Destinations
Turning OFF the machine or setting <Restrict New Destinations> to <On> deletes the past destinations, preventing you from recalling them. Limiting Available Destinations
The destinations in Manual Sending are not available for this function.
When you specify a destination using this function, any destinations that you have already specified are deleted.
(Recall Settings).
