Use the numeric keys on the operation panel to specify destinations.
When <Restrict New Destinations> is set to <On>, you cannot use the numeric keys to specify destinations.
. (Press to delete each character one by one. Press and hold to delete all the input characters at once.)
before repeating the same procedure. Up to 10 destinations can be specified.
To delete destinations
1
Select <Confirm/Edit Destination>, and press
2
Select a destination you want to delete, and press
3
Select <Delete Destination>, and press
4
Select <Yes>, and press
If you want to easily and quickly delete destinations without displaying a list of destinations
Before selecting <Confirm/Edit Destination> in step 1, you can press
/ to toggle the destinations you specified. Display a destination you want to delete <Yes> . |
