      0KCF-02S
      Changing Default Copy Settings
      Change the default settings to match the operations that you perform frequently.
        <Copy Settings>    <Change Default Settings>    Select the setting    Change the default value of the selected item  <Apply>
      Settings
      Select the item you want to set, and change the default value.
