The machine comes pre-configured with factory default settings (Setting Menu List). You can change and register the default settings according to your needs.
Change the copy ratio to 95% and register it as the default setting. From now on, you can make copies without changing the copy ratio. Changing Default Copy Settings
Go to <Favorite Settings> and register the combination of <2-Sided> and <Collate> turned <On>. You can then easily use this setting combination whenever you need it. Registering Frequently Used Copy Settings
