to cancel the entered quantity.
When placing documents in the feeder in step 1
When placing documents on the platen glass in step 1
1
Use
/ to select the document size, and press .![]() |
2
Select the paper source that contains the paper you want to use, and press
.![]() If the screen is not displayed, proceed to step 3.
3
Place the next document on the platen glass, and press
.Repeat this step until you finish scanning the entire document.
4
Select <Start Copying>, and press
(Status Monitor)
<Copy/Print Job>
<Copy Job Log>
select the copy document you want to check
When copying documents with text or images that extend to the edges of the page
The edges of the document might not be copied. For more information about the scan margins, see Scan Area.
TIPS
If you always want to make copies with the same settings:
If you want to register frequently used setting combinations:
If you want to save toner for copying:
