You can copy two documents on both sides of the paper. You can also copy a two-sided document on both sides of the paper, or on two separate pages (imageRUNNER 1435iF / 1435i only).
<2-Sided> may not be available with some sizes and types of paper.
<2-Sided> is not available when using <ID Card Copy>.
You can specify the 2-sided copy setting by pressing
(2-Sided), instead of selecting <2-Sided> as the procedure described below. |
<2-Sided>
Set 2-sided copying
Types of 2-sided copying|
1->2-Sided
2->2-Sided*
2->1-Sided*
* Only available for the imageRUNNER 1435iF / 1435i.
<Original/Finishing Type>
1->2-Sided
<1->2-Sided>
<Portrait>
<Calendar Type>
<1->2-Sided>
<Landscape>
<Book Type>
2->2-Sided (imageRUNNER 1435iF / 1435i only)
<2->2-Sided>
Select the original orientation
Select the original binding type
Select the binding type for the finished copy, which is different from that of the original document
2->1-Sided (imageRUNNER 1435iF / 1435i only)
<2->1-Sided>
<Portrait>
<Calendar Type>
<2->1-Sided>
<Landscape>
<Book Type>
