1
Select the registered size you want to change, and press
2
Select <Edit>, press
1
Select the registered size you want to delete, and press
2
Select <Delete>, and press
3
Select <Yes>, and press
1
Specify the length of the <X> (shorter) side.
Select <X>, and press
![]() Input the length of the <X> side using
2
Specify the length of the <Y> (longer) side.
Select <Y>, and press
![]() Input the length of the <Y> side, and press
3
Select <Apply>, and press
