If the screen shown above is not displayed when paper is loaded
If you always load the same paper in the multi-purpose tray, you can skip the paper setting operations by registering the paper size and type as the default setting. When the default setting is registered, however, the screen shown above is not displayed. To display the screen, select <Off> for <Register Default Set.> (Registering Default Paper Settings for the Multi-Purpose Tray).
to select the paper size, and press
When loading custom size paper
1
Select <Custom>, and press
2
Specify the length of the <X> (shorter) side.
Select <X>, and press
.Input the length of the <X> side using
/ , with / to move the cursor between the digits for inputting whole numbers and fractions, and press .![]() |
3
Specify the length of the <Y> (longer) side.
Select <Y>, and press
.Input the length of the <Y> side, and press
4
Select <Apply>, and press
