After the default paper setting is registered, the paper setting screen is not displayed when paper is loaded, and the same setting is always used. If you load a different paper size or type without changing the paper settings, the machine may not print properly. To avoid this problem, disable the default setting by selecting <Off> in step 3, and then load the paper.
1
Select <Custom>, and press
2
Specify the length of the <X> (shorter) side.
Select <X>, and press
![]() Input the length of the <X> side using
3
Specify the length of the <Y> (longer) side.
Select <Y>, and press
![]() Input the length of the <Y> side, and press
4
Select <Apply>, and press
