About the menu options in the following chart
Default settings are highlighted in bold.
Settings
Descriptions
Special Mode U
Due to the paper type (e.g. heavy paper) or usage conditions (e.g. dry conditions), toner smudges and spatters appear on the output. When this occurs, set the setting to ON.
Special Mode V
Paper (the printed side) curls when damp paper is used to print. When this occurs, change the setting.
Special Mode X (only for media printing and printing from PS/PCL printer driver)
Toner smudges and spatters appear on the output, due to the paper type or usage conditions. When this occurs, change the setting.
Special Mode Z (only for copying)
Special Mode B
Toner smudges and spatters appear on the output, when the toner cartridge was replaced recently, or the machine has not printed anything for an extended period of time. When this occurs, change the setting.
Special Mode C (only for printing received fax and report printing)
Toner smudges and spatters appear on the output, due to the paper type or usage conditions. When this occurs, set the setting to ON. In addition, the machine runs more quietly in the middle of a print run when this setting is set to ON.
Special Mode D
