Category
Top » Maintenance » Cleaning the Machine » Cleaning the Feeder Automatically
Category Top
Cleaning the Exterior
Cleaning the Fixing Unit
Cleaning the Platen Glass
Cleaning the Feeder
Attention (Cleaning the Machine)
Replacing Toner Cartridges
Before Replacing the Toner Cartridge
Attention (Replacing the Toner Cartridge)
Adjusting the Machine
Correcting Copy Images
Attention (Correcting Copy Images)
Adjusting the Density
Adjusting Black Text in Color Documents (Black Text Processing Adjustment in Color Documents)
Special Mode
Relocating the Machine
Attention (Relocating the Machine)
Collapse all|Expand all
07K4-0W9
If your document has black streaks or appears dirty after it has been scanned from the feeder, the rollers inside the feeder may be dirty. Clean the roller using blank paper.
1
Press [] (Menu).
2
Select <Adjustment/Maintenance> using [] or [] and press [OK].
3
Select <Clean Feeder> using [] or [] and press [OK].
4
Load 10 sheets of A4 or Letter size plain paper in the feeder, and then press [OK].
The cleaning begins. It takes approximately 44 seconds to complete the process.
5
Press [] (Menu) to close the menu screen.
