Paper Jams in the 2-sided Transport Guide
07K4-0SK
1
Press [
Press [OK] to exit the operation screen.
2
Pull out the paper drawer.
3
Holding the green tabs (A), open the 2-sided transport guide.
4
Remove the jammed paper by pulling it out gently.
If it cannot be removed easily, do not pull it forcibly. Proceed to Step 5.
5
Holding the green tabs, close the 2-sided transport guide securely.
Make sure that both ends of the paper exit guide are closed.
6
Set the paper drawer.
7
When the following screen appears, select <Yes> using [
] and press [OK].
The machine is ready to print.
