Category
Top » Troubleshooting » Clearing Jams » Paper Jams in the Multi-Purpose Tray
Category Top
Error Codes
When a Power Failure Occurs
Clearing Jams
Document Jams in the Feeder
Paper Jams in the Output Area
Paper Jams in the Paper Drawer (Drawer 1 or 2)
Paper Jams in the Back Cover and Duplex Unit
Paper Jams in the Front Cover
Paper Jams in the 2-sided Transport Guide
When <Incorrect Size/Setting> Appears
Onscreen Messages
Troubleshooting
Paper Feeding Problems
Fax Problems
Sending Problems
Cannot Send a Fax
Receiving Problems
Modes Cannot Switch Automatically between Telephone and Fax
Faxes Cannot Be Printed, or the Images on Printouts Are Spotted or Distorted
Copying Problems
The Copy Output Is Hardly Readable and Copied Poorly
Printing Problems
Cannot Print Documents from a Computer
Cannot Print over a TCP/IP Network
Scanning Problems
Cannot Scan a Document
Telephone Problems
Network Problems
Wired LAN Troubles
Checking Network Connection (Wired LAN)
Wireless LAN Troubles
Checking Network Connection (Wireless LAN)
Installation and Uninstallation Problems
Miscellaneous Problems
Printing Results Are Not Good
Paper Curls
Paper Creases
Vertical Streaks Appear on the Output
Toner Smudges and Spatters Appear around Text and Images
The Bottom Edge of Paper or Following Paper Has Smudge Marks
A Portion of the Page Is Not Printed
Uninstalling the Software
When a Problem Cannot Be Resolved
Collapse all|Expand all
07K4-0SE
Referring to the procedure on the display, follow the steps below to remove jammed paper.
1
Press [].
2
Remove the jammed paper by pulling it out gently.
If it cannot be removed easily, do not pull it out forcibly. Perform the procedure at the position that is indicated on the message display.
3
When the following screen appears, select <Yes> using [] and press [OK].
The machine is ready to print.
