Restrictions for setting up a computer running a 64-bit operating system as the print server
To set up a computer running a 64-bit operating system as the print server, the alternate printer driver cannot be downloaded from the network onto computers using the following 32-bit operating systems.
Windows XP (without service packs or SP1 installed)
Windows Server 2003 (without service packs installed)
Note that installation may fail if you try to download the driver onto a computer using any of these operating systems. If the download is successfully completed, you may not be able to open the printing preferences dialog box.
Restrictions for setting up a computer running a 32-bit operating system as the print server
To set up a computer running one of the following 32-bit operating systems as the print server, the alternate printer driver cannot be downloaded from the network onto computers using 64-bit operating systems.
Windows XP (on which no service pack or SP1 is installed)
Windows Server 2003 (on which no service pack is installed)
Right-click the icon for the machine and select [Printer properties] from the pop-up menu.
Display the [Sharing] tab.
When [Change sharing options] appearsClick [Change sharing options].
When the [User Account Control] dialog box appears, click [Continue]. |
Continue with the steps in the procedure below and install the alternate printer driver on your computer.
To install the printer driver on another computer
