Printing Files as a List (Index Printing)
Print the list of files, dates, and file names saved in USB memory.
TIFF (MMR/JPEG Image) format files does not support index printing.
1
Insert a USB memory media into the USB memory port.
The machine will begin to read the device when a USB memory is inserted. Do not touch or remove the device from the port.
2
Press [
3
Select <Index Print> using [
] or [
] and press [OK].
4
Select a file to print.
5
Specify the print settings as needed.
The following settings can be changed.
Quantity
Paper
Brightness
The settings specified here are effective only for the current task. To make the settings effective for all operations, see "
Changing the Default Values for Media Printing."
6
Press [
] (Start).
Printing begins.
When removing the USB memory media form the port
Press [  ] (Reset).
Press [  ] (Status Monitor/Cancel).
Select <Device Status> using [  ] or [  ] and press [OK].
4.
Select <Remove Memory Media> using [  ] or [  ] and press [OK].
5.
Remove the USB memory media.
6.
Press [  ] (Status Monitor/Cancel) to close the screen.
