Category
Top » Printing » Printing Documents from a USB Memory (Media Printing) » Changing the Default Values for Media Printing
Category Top
Printing Documents from a Computer
Preparing to Print from Your Computer
Configuring Port Settings over a TCP/IP Connection
Setting Up Printer Sharing
Printing Fundamentals
Printing
Setting the Printer Options
Viewing the Online Help
Printing Functions
Common Functions
[Page Setup] Sheet
[Finishing] Sheet
[Paper Source] Sheet
[Quality] Sheet
[Device Settings] Sheet
Scaling Documents
1-sided Printing and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Checking and Deleting Print Jobs/Checking Print Job History
Checking and Canceling Print Jobs
Changing printer settings (Items to Be Specified Using [Menu] Button)
Summary of Media Printing
Printing Fundamentals (USB Memory)
Selecting a file to print
Changing Print Settings
Attention (Changing Print Settings)
Printing Files as a List (Index Printing)
Changing File Name Display Formats
Collapse all|Expand all
07K4-0CR
The default values of media printing means a function which is applied when [] (Reset) is pressed or the power is turned ON. You can modify these settings based on your needs.
You can change the following default settings based on your needs.
Quantity
Paper Selection
N on 1
Date Printing
File name printing
Document Type
Brightness
File Sorting
1
Press [] (Menu).
2
Select <USB Direct Print Settings> using [] or [] and press [OK].
3
Select <Change Defaults> or <File Sort Default Settings> using [] or [] and press [OK].
When <Change Defaults> is selected
(1)
Select the item to specify using [] or [] and press [OK].
For details on the settings, see the following items.
(2)
Select <Apply> using [] or [] after you have specified the setting and press [OK].
When <File Sort Default Settings> is selected
(1)
4
Press [] (Menu) to close the menu screen.
