Selecting a file to print
07K4-0CF
This section describes how to select a file to print.
1
Select a file you want to print using [
] or [
] and press [OK].
] at the beginning of the file name is displayed.
To select more than one file
Repeat Step 1 to add [  ] to the beginning of all file names you want to select.
You can select more than one files if they are in the same folder. Unselected if you move to a different folder.
To select all files in the same folder
Select <Select All> using [  ] or [  ] and press [OK].
To select a file in the folder
Select a folder using [  ] or [  ] and press [OK] or [  ].
Select a file you want to print using [  ] or [  ] and press [OK].
To clear the selection
Select a file you selected using [  ] or [  ] and press [OK].
To clear all selected files, select <Clear All> using [  ] or [  ] and press [OK].
