Printing Fundamentals (USB Memory)
Print the data saved in the USB memory media connected to this product.
This section describes the basic procedure.
1
Insert a USB memory media into the USB memory port.
The machine will begin to read the device when a USB memory is inserted. Do not touch or remove the device from the port.
2
Press [
3
Select <Select File(s) to Print> using [
] or [
] and press [OK].
To sort files
Select <Sort Files> using [  ] or [  ] and press [OK].
Select items to specify using [  ] or [  ] and press [OK].
4
Select a file to print.
5
Specify the print settings as needed.
The following settings can be changed.
Quantity
Paper
N on 1
Date Printing
File name printing
Document Type
Brightness
The settings specified here are effective only for the current task. To make the settings effective for all operations, see "
Changing the Default Values for Media Printing."
6
Press [
] (Start).
Printing begins.
When removing the USB memory media form the port
Press [  ] (Reset).
Press [  ] (Status Monitor/Cancel).
Select <Device Status> using [  ] or [  ] and press [OK].
4.
Select <Remove Memory Media> using [  ] or [  ] and press [OK].
5.
Remove the USB memory media.
6.
Press [  ] (Status Monitor/Cancel) to close the screen.
