For details on the procedure for viewing "Printer Driver Installation Guide", see "Installation."
When using LPD
When the printer driver is installed using the above method, RAW is specified as the print application to be used. If you want to use LPD, install the printer driver using the above procedure, and then change a port.
(1)
Display the [Ports] tab.
(2)
Click [Add Port].
(1)
Select [Standard TCP/IP Port].
(2)
Click [New Port].
(1)
Enter the IP address or name* of the printer in [Printer Name or IP Address].
(2)
Click [Next].
If the printer cannot be detected
The following screen appears. Perform either of the following operations.
Follow the on-screen instructions and search again for the printer.
Specify the setting for [Device Type].
If you are not sure about the value to enter
The value to be entered varies depending on how the IP address of the printer was set.
For more details, see "Values for Setting a Port" or ask your network administrator. |
(1)
Click [Configure Port].
(2)
Select [LPR].
(3)
Enter "lp" in [Queue Name].
(4)
Click [OK].
When deleting an unnecessary port
Select the unnecessary port on the [Ports] tab, and then click [Delete Port].
About the setting procedure
The procedure described here is a setting example. Depending on the system environment, the setting procedure may be different.
Specify the settings also when using a computer on which UNIX OS is installed as a stand-alone workstation along the procedure described here.
If you do not have the root user permission on the UNIX server
Consult your network administrator.
Open the "/etc/hosts" file using a text editor.
Add the following line.
After saving the "/etc/hosts" file, exit the text editor.
Be sure to assign a fixed IP address to the printer.
When printing from UNIX OS, be sure to assign a fixed IP address to the printer. For details on the procedure for setting the IP address, see "Setting the IP Address (IP v. 4)."
Enter the following in the "/etc/printcap" file.
Create the spool directory for the printer. Execute the following commands.
Create the log file for the printer. Execute the following commands.
4.
Proceed to Step 4.
Run "admintool."
Select [Browse] → [Printers].
Select [Edit] → [Add] → [Access to Printer].
4.
Enter an arbitrary print queue name in [Printer Name], and then enter the IP address or name of the printer in [Print Server].
5.
Select [OK].
6.
Proceed to Step 4.
Run "SAM."
Select [Printers and Plotters].
Select [LP Spooler] from the [Printers and Plotters] menu.
4.
Select [Printers and Plotter] from the [LP Spooler] menu.
5.
Select [Add Remote Printer/Plotter] from the [Action] menu.
6.
Enter an arbitrary print queue name in [Printer Name], and then enter the IP address or name of the printer in [Remote System Name].
7.
Enter "lp" in [Remote Printer Name].
8.
Select [Remote Printer is on a BSD System].
9.
Select [OK].
10.
Proceed to Step 4.
Run "SMIT."
Select [Print Spooling] → [Add a Printer Queue] → [remote].
Select [Standard processing].
4.
Enter an arbitrary print queue name in [remote queue name] and the IP address or name of the printer in [Hostname of Remote Server].
5.
Enter "lp" in [name of the queue] on the remote server.
6.
Enter "BSD" in [type of print spooler] on the remote server.
7.
Proceed to Step 4.
Form:
lp -d <the print queue name> <the name of the file to be printed>
Input Example:
lp -d print_queue_name report
