Perform one of the following solutions according to the cause.
<Cause 1>Paper is not loaded properly in the paper drawer or multi-purpose tray.
Solution
Load the paper properly.
<Cause 2> Damp paper is used.
Solution 1
Replace the paper with new paper in an unopened package.
Solution 2
Perform the following procedure in the printer driver.
Display the [Finishing] tab.
Click [Advanced Settings].
Set [Wrinkle Adjustment] to [Mode 1].
If the problem is not solved, specify [Mode 2].
If the problem is not solved, set [Curl Adjustment] to [On].
When you use thin paper (16.0 to 19.8 lb Bond (60 to 74 g/m²)), setting [Paper Type] to [Plain L] and [Special Print Mode C] to [On] may prevent paper creases.
[Special Print Mode C] can also be set* using the printer's control panel.
The setting of [Special Print Mode C] overrides the setting of [Wrinkle Adjustment].
<Setting Method for [Curl Adjustment]>
Set [Curl Adjustment] to [On].
If you specify these settings, the printing speed drops in stages.
Specifying these settings may result in poor print quality.
If activating [Wrinkle Adjustment] results in poor print quality, set [Curl Adjustment] to [On]. The print quality may improve.
<Cause 3> Appropriate paper is not being used.
Solution
Replace the paper with that which can be used with this printer.
<Cause 4> There is a foreign object inside the printer.
Solution
Remove the foreign object inside the printer.
