Solution 1
Replace the paper with new paper in an unopened package.
Solution 2
Perform the following procedure in the printer driver when you are using plain paper (16.0 to 23.9 lb Bond (60 to 90 g/m²)).
Solution 3
You can specify the same setting from the printer's control panel.
Solution
Replace the paper with that which can be used with this printer.
Solution
Switch to the sub-output tray when printing transparencies, labels, or envelopes.
