» Configuring the Network Settings (Sharing the Printer) » Network Settings for the Printer (Common to Each Protocol) » Setting the Spooling Function
Specify the setting for the spooler function using either of the following methods.
Specify the setting for the spooler function using the control panel while checking the display on the printer.
Specify the setting for the spooler function by accessing the printer from a Web browser via the network.
When specifying the setting for startup waiting time first
Use the printer's control panel. After configuring the TCP/IP protocol settings, you can change the settings using the Web browser (Remote UI) or FTP Client.
Because the options which can be specified vary depending on the software, see "Network Setting Items" and use each software appropriate to the environment you are using or options that you want to specify.
The Spooling Function
It can only be used when the SD card is installed.
Changing the settings using FTP Client
You can also specify the setting for startup waiting time using FTP Client.
051R-07J
