» Configuring the Network Settings (Sharing the Printer) » Network Settings for the Printer (Common to Each Protocol)
This section describes the setting items which are common to each protocol to use this printer in a network environment.
Selecting a Communication Method or Ethernet Type
If you want to fix the type of communication method and Ethernet type, set [Auto Detect] on the Ethernet Drive Setting to [Off]. (This printer can detect the communication method and Ethernet type automatically. Normally, you do not need to specify the setting.)
Specifying the Setting for Startup Waiting Time
If the printer cannot be connected to a network, see the following item and specify the setting for the startup waiting time. (Normally, you do not need to change the setting for startup waiting time.)
Setting the Spooling Function
You can speed up the exiting time of the computer to which you send print jobs, see the following item and configure the spooler function.
Restricting the Users Who Can Monitor and Change the Settings
If you want to restrict the users who can monitor and change the settings, see the following items and configure the SNMP protocol.
Setting IEEE802.1X Authentication
You can specify the settings for using IEEE802.1X authentication with the printer.
Network Setting Items
This section describes the setting items which you can change using a Web browser (Remote UI), FTP Client, or NetSpot Device Installer.
Initializing the Network Settings
You can reset the network settings for the printer to the default values.
Checking the MAC Address
You can check the MAC address by printing Network Status Print.
051R-07C
