» Configuring the Network Settings (Sharing the Printer) » Network Settings for the Printer (Common to Each Protocol) » Changing the Network Transmission Speed or Transfer Mode
Configure the Ethernet driver for this printer using either of the following methods.
Configure the Ethernet driver using the control panel while checking the display on the printer.
Change the settings for the Ethernet driver by accessing the printer from a Web browser via the network.
When configuring the interface first
Use the printer's control panel. After configuring the TCP/IP protocol settings, you can change the settings for the interface using the Web browser (Remote UI).
Ethernet
Ethernet is a LAN standard, and this printer supports 10Base-T/100Base-TX/1000Base-T connections. When this printer is used on a network, the Ethernet driver controls the communication method and Ethernet type.
051R-07E
