» Useful Printing Functions » Printing Files Directly from USB Memory Devices (USB Direct Print) » Changing the Default Print Settings and File Sorting Criteria
1
Press [  ] (Application).
The "USB Direct Print Mode Screen" is displayed.
When department ID management is set, the screen is displayed when the departmental ID and PIN are entered. After entering the department ID and PIN, select [<Log In>], and then press [OK].
2
Select [USB Print Settings] with [] and [], and then press [OK].
3
Select items for which to set default values using [] or [], and then press [OK].
Set default print settings
(1)
Select [PDF/XPS Default Set.] or [JPEG/TIFF Def. Set.] using [] or [], and then press [OK].
(2)
Set the default value of each item.
For details on the settings, see "Print Setting Menu List."
Setting default values for file display sorting criteria
(1)
Select [File Sort Def. Set.] with [] and [], and then press [OK].
(2)
Select the default sorting criteria using [] or [], and then press [OK].
051R-06E
