» Useful Printing Functions » Printing Files Directly from USB Memory Devices (USB Direct Print) » Printing Directly from USB Memory Device
1
Insert the USB memory device in the USB memory slot on the printer.
2
Press [  ] (Application).
The "USB Direct Print Mode Screen" is displayed.
When department ID management is set, the screen is displayed when the departmental ID and PIN are entered. After entering the department ID and PIN, select [<Log In>], and then press [OK].
In order to automatically display the USB direct print mode screen
When the [Automatically Display USB Direct Print Screen] setting is checked on [USB Direct Print] in the [USB Direct Print Settings] on the Remote UI, the "USB Direct Print Mode Screen" is displayed automatically when a USB memory device is inserted.
3
Select [Select File(s)] with [] and [], and then press [OK].
Changing the order of the files displayed in Step 5
(1)
Select [Sort Files] with [] and [], and then press [OK].
(2)
Since the message is displayed, press [OK].
(3)
Select the sorting criteria with [] and [], and then press [OK].
4
Select the type of file to print with [] and [], and then press [OK].
5
Select the file to print with [] and [], and then press [OK].
[  ] will be attached to the file name. If a file with [  ] attached is selected, and [OK] is pressed again, the selection is removed.
If a folder is selected, and [OK] is pressed, the list of files inside the folder is displayed.
If [<Clear All>] is selected, all the file selections are removed.
Up to 10 files in the same folder can be selected.
If the folder hierarchy is moved, all of the file selections are removed.
6
Select [<Apply>] with [] and [], and then press [OK].
When printing using an XPS file print ticket
(1)
Select [<Use Print Ticket>] with [] and [], and then press [OK].
(2)
Select [<Start Printing>] with [] and [], and then press [OK].
It is printed using the print settings specified inside the file.
7
To confirm/ change the print settings, select the setting to be confirmed/changed with [] and [ ], and then press [OK]. For details on print settings, see "Print Setting Menu List."
The selected file begins printing.
Remove the USB memory device after printing has finished.
"Remove the USB Memory Device"
051R-06A
