Paper Drawer
Width 4.13 to 8.50 in. (105.0 to 215.9 mm), Length 5.83 to 14.00 in. (148.0 to 355.6 mm)*1
Multi-purpose tray
Width 3.00 to 8.50 in. (76.2 to 215.9 mm), Length 5.00 to 14.00 in. (127.0 to 355.6 mm)*2
*1
If you are using the UFR II printer driver, you can load custom size paper that is 5.83 to 8.50 in. (148.0 to 215.9 mm) wide and 5.83 to 8.50 in. (148.0 to 215.9 mm) long in landscape orientation.
*2
If you are using the UFR II printer driver, you can load custom size paper that is 5.00 to 8.50 in. (127.0 to 215.9 mm) wide and 5.00 to 8.50 in. (127.0 to 215.9 mm) long in landscape orientation.
: Available|
Paper Type
Paper Drawer
Multi-purpose Tray
Plain paper (16.0 to 23.9 lb Bond (60 to 90 g/m²))
Heavy paper (24.0 lb Bond to 44.4 lb Cover (91 to 120 g/m²))
Heavy paper (44.5 to 60.3 lb Cover (121 to 163 g/m²))
The print speed drops when printing on heavy paper (24.0 lb Bond to 60.3 lb Cover (91 to 163 g/m²)).
