When loading custom size paper in the multi-purpose tray
Load them the same way as standard size paper.
For details on the paper that you can load in the paper drawer, see "Usable Paper."
Load paper in Drawer 2 (optional) in the same manner as you load paper in Drawer 1.
Before loading paper, see "Attention (Paper Drawer)."
About the paper loading orientation
If you are not using the UFR II printer driver, load paper in portrait orientation.
Also, be sure to load paper in landscape orientation if all the following conditions are met. You are using the UFR II printer driver.
[Drawer 1 Size] and [Drawer 2 Size] are set to [Mixed Sizes].
Custom size paper whose long edges are 8.50 in. (215.9 mm) or less is loaded.
When loading paper with a letterhead or logo
See "Paper Loading Orientation" and load the paper in the correct orientation.
When loading paper shorter than A5:
Adjust the paper guide at the rear center to fit the length of paper.
Be sure to align the paper guides to the paper.
If the paper guides are too loose or too tight, this may result in paper being misfed or paper jams.
Be sure that the paper stack does not exceed the load limit mark lines. If the paper stack exceeds the load limit mark lines, this may result in paper being misfed.
