Heavy paper of 44.5 to 60.3 lb Cover (121 to 163 g/m²) can only be loaded in the Multi-purpose tray.|
Paper Drawer
Multi-purpose Tray
Standard sizes
A4*1, B5, A5, A6, Legal*1, Letter*1, Executive and 16K
A4*1, B5, A5, A6, Legal*1, Letter*1, Executive, Statement, 16K and Index Card
Custom paper sizes
Width 4.13 to 8.50 in. (105.0 to 215.9 mm), Length 5.83 to 14.00 in. (148.0 to 355.6 mm)*2
Width 3.00 to 8.50 in. (76.2 to 215.9 mm), Length 5.00 to 14.00 in. (127.0 to 355.6 mm)*3
*1
Can be used for 2-sided printing (44.5 to 60.3 lb Cover (121 to 163 g/m²) heavy paper cannot be used).
*2
If you are using the UFR II printer driver, you can load custom size paper that is 5.83 to 8.50 in. (148.0 to 215.9 mm) wide and 5.83 to 8.50 in. (148.0 to 215.9 mm) long in landscape orientation.
*3
If you are using the UFR II printer driver, you can load custom size paper that is 5.00 to 8.50 in. (127.0 to 215.9 mm) wide and 5.00 to 8.50 in. (127.0 to 215.9 mm) long in landscape orientation.
Recycled paper can be also used.
When using custom size paper
: Available
: Unavailable|
Paper Type
Paper Drawer
Multi-purpose Tray
Plain paper (16.0 to 23.9 lb Bond (60 to 90 g/m²))
Heavy paper (24.0 lb Bond to 44.4 lb Cover (91 to 120 g/m²))
Heavy paper (44.5 to 60.3 lb Cover (121 to 163 g/m²))
Index Card
The print speed drops when printing on heavy paper (24.0 lb Bond to 60.3 lb Cover (91 to 163 g/m²)).
