Memory RX Inbox
The Memory RX (Receive) Inbox is an inbox for storing files received by I-Fax. Files received by the Memory RX Inbox are stored without being printed. You can print or send the stored files whenever necessary.
If you want to use Memory Lock, you must first set [Use I-Fax Memory Lock] to 'On'. (See "Specifying the I-Fax Inbox Settings.")
You cannot store any more files in the Fax/I-Fax Inbox in the cases described below. These numbers may vary depending on the remaining capacity of the hard disk.
When a total of 1,500 files or images are stored in the Mail Box and Fax/I-Fax Inbox
When a total of 6,000 pages of files or images are stored in the Mail Box and Fax/I-Fax Inbox
When there is insufficient memory available
If a message prompting you to enter the PIN appears, enter the number registered in [Memory RX Inbox PIN]. (See "Specifying the I-Fax Inbox Settings.")
» Fax/I-Fax Inbox » Memory RX Inbox » Memory RX Inbox
0S9Y-1S6
