e-ManualTopSite mapHelp
Top » Fax/I-Fax Inbox » Memory RX Inbox » Memory RX Inbox » Receiving Files Through I-Fax
0S9Y-1S7
You can set whether to automatically print received I-Faxes, or store them in the Memory RX Inbox.
Press (Main Menu) → [Fax/I-Fax Inbox] → [Memory RX Inbox].
Press [Memory RX Inbox].
Set <I-Fax Memory Lock>.
[On]:
Received files are stored in the Memory RX Inbox.
[Off]:
Received files are printed automatically.
If you have set [Memory Lock Start Time]/[Memory Lock End Time] in [Set Fax/I-Fax Inbox] in [Function Settings] (Settings/Registration), the following is displayed:
When you select [On] for <I-Fax Memory Lock>: The end time for Memory Lock is displayed.
When you select [Off] for <I-Fax Memory Lock>: The start time for Memory Lock is displayed.
If you set <I-Fax Memory Lock> to 'Off', files received through the I-Fax function are automatically printed and deleted from the Memory RX Inbox.
4.
Press [Back] repeatedly until the Inbox Selection screen appears.
