You can print stored files only with the same settings as when they were received.
Files stored in the Memory RX Inbox are automatically deleted after you print them.
You cannot print multiple files simultaneously. To print multiple files, select and print one file at a time.
If you set <I-Fax Memory Lock> to 'Off', files received through the I-Fax function are automatically printed and deleted from the Memory RX Inbox.
