POD Deck-D1/Secondary POD Deck-D1 (Optional)
If a paper jam occurs in the POD Deck-D1/Secondary POD Deck-D1, a screen prompting you to remove the jammed paper appears on the touch panel display. Check the location of the paper jam, and follow the procedure described below, while referring to the directions that appear on the touch panel display, to remove the jammed paper.
» Problem Solving » Clearing Paper Jams » POD Deck-D1/Secondary POD Deck-D1 (Optional)
0S9Y-1LW
