You can clear a paper jam which occurs when the POD Deck-D1/Secondary POD Deck-D1 is attached, by following the same procedure for clearing a jam paper when only the is attached.
The following illustration indicates the location of the paper jam. Please refer to it to remove the jammed paper.
If only the POD Deck-D1 is attached:
![]() If the POD Deck-D1/Secondary POD Deck-D1 is attached:
The labels on the Secondary POD Deck-D1 side are indicated with Da- (ex: Da-A1), and on the POD Deck-D1 side are indicated as Db-.
CAUTION |
When closing the guide, be careful not to get your fingers caught, as this may result in personal injury.
CAUTION |
CAUTION |
When closing the cover, be careful not to get your fingers caught, as this may result in personal injury.
The screen indicating the directions on how to clear the paper jam is displayed repeatedly until the paper jam is cleared. (See "Clearing Paper Jams.")
