Paper Decks
This section describes how to clear a paper jam which occurs in the paper deck of the POD Deck-D1/Secondary POD Deck-D1. The location of the paper decks is indicated in the following illustration.
Follow the procedure described below, while referring to the location of the paper jam and the directions that appear on the touch panel display, to remove the jammed paper.
Push the open button of the paper deck indicated on the touch panel display.
Make sure to close all covers and paper drawers of the machine before clearing any staple jams.
If the machine is in the Sleep mode (the touch panel is not displayed, and only (Energy Saver) is lit), you may be unable to open the paper deck. In this case, press (Energy Saver) to reactivate the machine, and then press the open button on the paper deck.
Grip the handle, and pull out the paper deck until it stops.
Remove any jammed paper.
4.
Gently push the paper deck back into the machine until it clicks into place in the closed position.
CAUTION
When returning the paper deck to its original position, be careful not to get your fingers caught, as this may result in personal injury.
5.
Follow the instructions on the touch panel display.
The screen indicating the directions on how to clear the paper jam is displayed repeatedly until the paper jam is cleared. (See "Clearing Paper Jams.")
» Problem Solving » Clearing Paper Jams » POD Deck-D1/Secondary POD Deck-D1 (Optional) » Paper Decks
0S9Y-1R7
