Checking the Status of Consumables and Other Information
You can check the status of consumables, such as the remaining amount of toner and staples. You can also check the backup status of the stored data.
Press
(Status Monitor/Cancel).
Press [Toner/Other].
To check toner and other information:
Check the remaining amounts of toner and staples, the percentage of memory usage, and amount of waste toner.
The remaining amount of toner is displayed in 1 % increments. The details of the displayed remaining amount of toner are shown below.
Remaining amount of toner
Status
Replacement of the toner cartridge
100% to 11%
OK
Replacement is not needed.
10% to 6%
Low
Replacement will be needed soon.
5% to 1%
Empty (Buffer toner remains.)
Replace the toner cartridge.
0%
Empty (Buffer toner is empty.)
The details of the displayed remaining amount and waste amount of other consumable are shown below.
Display
Remaining amount of cleaning web
OK
100% to 8.5%
Nearly Low
8.5% to 2.1%
Low
2.1% to 0%
Empty
0%
Display
Remaining amount of staples
Remaining amount of saddle stitch staples Remaining amount of glue
OK
100% to 26%
Low
25% to 1%
Empty
0%
Display
Amount of waste toner
OK
0% to 95%
Near Full
96% to 99%
Full
100%
Not Set*
Display
Punch Waste
Punch Waste in Puncher Unit Staple Waste Trimmer Book Waste Perfect Binder Waste
OK
0% to 95%
Near Full
96% to 99%
Full*1
100%
Not Set*2
*1 It is displayed when the punch waste container of the finisher is not placed correctly as well. Place the container correctly.
*2 The waste container such as a waste tray is placed incorrectly. Replace the waste container.
To check the backup status of the stored files:
Check the backup status of the stored files.
The table below indicates the the backup status.
Display
Stauts
Backup is available.
Processing
Backing up stored files.
Press [Close].
